Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 4.6l and tranny swap into my '88 T-bird
  1. #11
    Join Date
    Aug 2017
    Location
    Texas
    Posts
    10
    Feedback Score
    0
    Default
    Quote Originally Posted by Haystack View Post
    It will fit, its not much different then a 4.6 swap on a fox stang. I wouldn't mind seeing it done. If you already have the block and parts, I say go for it.
    First thing though, mustsng motor mounts don't work with the stock k-member. I would probably swap to a tubular unit for more clearance, adjustability and to use stang mounts.
    Wiring will have to be taken from either a donor car or wired up using a stand alone aftermarket job.
    Everything else should pretty much go right in.
    Ive dropped an adjustable k-member in from lmr, so thats taken care of. Also, the 4.6 and trans will be coming out of my '08 p71, the rear axle busted and figured i could just use that beast for the donor. I have the wiring and everything. Also, both the engine and trans have been rebuilt with better internals and last i checked it was pushing 301hp at the wheels( i plan on getting those numbers up)
  2. #12
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,257
    Feedback Score
    2 (100%)
    Default
    Quote Originally Posted by Nathan88bird View Post
    So, would it be worth more my while if i just dropped a t-5 in and beefed up the 302? that would always be an option. there is a local guy selling an HO motor for 400$ i could nab and beef that up perhaps?
    Honestly, it would be much easier.
    Which motor and wiring is the car setup for now? If its already a 302/aod car, then its a bolt in swap with very few changes to drop in or covert to a h.o. motor.
    Check out coolcats.net and do some reading.
    Quote Originally Posted by jcassity
  3. #13
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    465
    Feedback Score
    3 (100%)
    Default
    Its not on the road but the motor swap is pretty much done.
    http://www.foxtbirdcougarforums.com/...63-My-85-TBird
    4.6 k member spaced 5/8 down under main rails 1/8 under lower mount. Modded rad support to fit 4.6 coolers. I modded the trans cross member mounts but I believe you can purchase a custom cross member. Custom drive shaft. Computer sent in to eliminate PATS and set up for a return type fuel system. Lots of things to consider, hood clearance, exhaust clearance, custom ac lines etc.
  4. #14
    Join Date
    Aug 2017
    Location
    Texas
    Posts
    10
    Feedback Score
    0
    Default
    Quote Originally Posted by bodyman View Post
    It’s not on the road but the motor swap is pretty much done.
    4.6 k member spaced 5/8” down under main rails 1/8” under lower mount. Modded rad support to fit 4.6 coolers. I modded the trans cross member mounts but I believe you can purchase a custom cross member. Custom drive shaft. Computer sent in to eliminate PATS and set up for a return type fuel system. Lots of things to consider, hood clearance, exhaust clearance, custom ac lines etc.
    What a great project bodyman! I would love to see it finished! Also, I have the mechanical ability to do it so I'm not too worried �� I can't wait to read your entire write up
  5. #15
    Join Date
    Oct 2005
    Location
    Chestermere, Alberta Canada
    Posts
    542
    Feedback Score
    1 (100%)
    Default
    Found it on NATO under modular swap
    http://natomessageboard.com/ubbthrea...rue#Post247500
    1988 Thunderbird Sport. No engine, no trans, turbocoupe disk diff with 3:27 gears, 31 spline axles and Cobra clutch packs, Turbocoupe front brakes.
  6. #16
    Join Date
    Oct 2005
    Location
    Posts
    542
    Feedback Score
    1 (100%)
    Default
    With the amount of Crown Vic P51 cars out there, that would be a good swap.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
