Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Any 9" bolt-in options for 85 turbobird?
  1. #11
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,072
    Feedback Score
    2 (100%)
    Default
    cobra rear, my bad
    https://youtu.be/5KwyBnX4UBw
    Quote Originally Posted by jcassity
  2. #12
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,072
    Feedback Score
    2 (100%)
    Default
    Here's how hard it is on a fox stang.
    https://youtu.be/7pFHFKcTP8Q
  3. #13
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,176
    Feedback Score
    4 (100%)
    Default
    C-clip eliminators suck at best. So why not just put 9" ends on an 8.8 housing and call it a day? You are going to order axles anyway so this would eliminate the c-clips. An SN95 Mustang 8.8 will bolt right into a Fox Bird and is the right width.
  4. #14
    Join Date
    Dec 2017
    Location
    parma, id
    Posts
    7
    Feedback Score
    0
    Default
    I'm actually taking a good look at this setup http://www.quickperformance.com/QP-1...ge_p_4015.html
    I've already got the 28spline lightweight spooled center section with 6.0 gears. I've already got the disk brakes. Compared to buying a disk brake 8.8, finding gears and spool, 9" ends And new shafts, plus the labor to set up/weld in the ends, cost wise likely similar but if i want to switch gears in the future, 9' is the way to go
    85 former turbo bird, circle track fodder. soon to be 11:1 351w, t5, spooled 6.0 geared 9" out back
Posting Permissions
  • You may not post replies
  • You may not edit your posts
