Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 66
Thread: Fast EFI and ram air......
  1. #31
    Join Date
    May 2005
    Location
    Newmarket, ON, Canada
    Posts
    167
    Feedback Score
    0
    Default
    Easy fix...just need to pin them directly to the dash harness or separate the harness. It doesn't go to the ECU.
    John
  2. #32
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,505
    Feedback Score
    135 (100%)
    Default
    I bloody hate electrical, but, I'll do it if I have to.
    '88 Sport--T-5,HURST shifter,TMoss GT-40 intake,Ed Curtis cam,Trick Flow heads,Scorpion rockers,70mm t-body,3G,mini starter,Taurus fan,BBK headers,O/R H-Pipe, Flowamaster 40's, deep and deeper Cobra R wheels,Mass Air, Mass Air and 24's,8.8 with 3.73's,140 mph speedo,Mach 1 chin spoiler,SN-95 springs,CHE control arms,aluminum drive shaft and a lot more..
  3. #33
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,168
    Feedback Score
    2 (100%)
    Default
    It turns on the fuel pump as well.
    I worked with an old fast efi system in a 2.3 turbo sand rail. It used an old turbo coupe harness re wires a bit.
    There was only like 10 wires plus the fuel injectors wires we needed to hook up.
    Electrical really isn't bad vinnie. With everything else you've done, it would be a cake walk.
    Quote Originally Posted by jcassity
  4. #34
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,505
    Feedback Score
    135 (100%)
    Default
    LOL. I hope it is. If all this happens, which it's looking like it will this spring, then I'll get the master kit and use the new inline fuel pump. Keep all of the Fast kit parts (or FiTech) that I can.
    I am starting to really look forward to the swap, and making the hood functional.
  5. #35
    Join Date
    Oct 2004
    Location
    Fort Wayne, Indiana
    Posts
    3,224
    Feedback Score
    9 (100%)
    Default
    FI tech has the fuel command center. its an under hood sump basically. Its mainly for carbed cars so you dont have to rework the entire fuel system to run it. the factory pump fills it and it has another self contained fuel pump that pumps to the throttle body.
    87 LX 302, E7's, ARP bolts, Mallory Unilite Distributor, MSD 6A, Edelbrock Performer Intake, Edelbrock 600 Carb, Flowtech Long tubes, 5Speed, 8.8w/4.10's, Granatelli Tube K-Member & LCA's, Coil Overs, KYB 4ways, CHE arms, 3" rear drop springs, BBK C/C Plates, SN-95 5-lug stuff, Fuel Cell, Battery Relocation, Mac Mufflers, Stinger Tails, Sunpro gauges, Custom Lip Spoiler
  6. #36
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,505
    Feedback Score
    135 (100%)
    Default
    I saw that, it's for a low pressure pump. I like the idea of the inline high pressure pump the FAST offers. I think FiTech also has the inline high pressure pump as well. I will call them and ask questions and do a lot of studying first.
  7. #37
    Join Date
    Oct 2004
    Location
    north carolina
    Posts
    510
    Feedback Score
    4 (100%)
    Default
    88 sport,TW heads, comp xe270hr, cobra u/Tmoss ported lower, 65 mm throttle body, under drives,smog delete,
    1.7 roller rockers, cai, k&n, bbk adj regulator, 76mm Pro-m,all MSD ign. MSD dist,18 base timing, 3g alt.1 5/8 ceramic headers, 255lph walbro, 2.5" h-pipe, flowmasters, silverfox valvebody, 3.73 gear,
    http://i216.photobucket.com/albums/c...d/DSCF0185.jpg ( RIP : ( )
  8. #38
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,505
    Feedback Score
    135 (100%)
    Default
    I saw that. I believe they have a master kit with that pump, O2 sensor/wideband, etc.
    I want the one big, do it all kit.
  9. #39
    Join Date
    Oct 2004
    Location
    Fort Wayne, Indiana
    Posts
    3,224
    Feedback Score
    9 (100%)
    Default
    Any updates?
  10. #40
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,505
    Feedback Score
    135 (100%)
    Default
    Update......
    First, my apologies for not updating. I know I hate it when I'm left hanging and waiting for updates from others, so I shouldn't do that.
    Now, decided to keep the SEFI. I swapped distributors, and the car is running very strong, and I'm about to do something I haven't done in a long time, but used to a lot....swapping the intake. I'm going to pull the tubular GT-40 and Tmoss ported lower to install a Trick Flow R Series intake and Accufab 75mm throttle body. Also, a few new ignition parts that I have in the garage, and new fuel pump.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
