Page 6 of 6 FirstFirst ... 23456
Results 51 to 52 of 52
Thread: deer hit repaint and misc interior redo & repair of 20th anny
  1. #51
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,042
    Feedback Score
    15 (100%)
    Default
    next up is to work on sealing the hood gaps so that when you close the hood, you dont let water down into the fender wells.
    ford gave us the perfect application part if you eyeball the the foam part that surrounds the hood hinges.
    I wish they continued the foam design and sent it all the way down the driver and passanger fender. they had a reason for making it short i guess???
    i will get this this new thing tomorrow eve i hope and wrap it up.
  2. #52
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,042
    Feedback Score
    15 (100%)
    Default
    here i have the hood body gaps sealed up.
    Lowes sells a really durable wide foam roll that is intended for the bottom of a garage door. I cut it long ways to make two seals along each fender.
    all this was simply put down with a hot glue gun.
    now water runs off the hood and follows the seal down to the header panel instead of falling into the fender wells and engine bay
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
