Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Vintage audio gear
  1. #11
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,679
    Feedback Score
    17 (100%)
    Default
    My dad has one of those and it still works.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  2. #12
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,477
    Feedback Score
    15 (100%)
    Default
    im also into older audio, the stuff you posted is rather newer than what i restore but, when you need caps/resistors/ and such, ping me first because i have what i think is a few thousand
  3. #13
    Join Date
    Oct 2004
    Location
    Pasadena, MD
    Posts
    7,428
    Feedback Score
    7 (100%)
    Default
    Quote Originally Posted by jcassity View Post
    Do you prefer the earlier tube amplifiers and radios?
  4. #14
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,477
    Feedback Score
    15 (100%)
    Default
    early tube radio's with the widest broadcast spectrum like my Hallicrafters S-38D. I also have a philco 46-1226
  5. #15
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,477
    Feedback Score
    15 (100%)
    Default
    here is the philco i restored last winter... but,, i restored it to "make it look like" it was restored in the 70's
    i did some mod's to the rectifier tube & the first two 6k6's to help kill the heat.... I also did a mod that PHilco never really solved on one particular resistor that kept burning up. I relocated it to the top, increased its wattage size to 5 times larger and then also put a heat sync on that as well.
    http://www.foxtbirdcougarforums.com/...ghlight=philco
    this one does not have a very wide broadcast spectrum, unlike my hallicrafters
    on my restore you can see where i took the time to stenciel each part with its designation to match the Code 125, Run 3 diagrams
Posting Permissions
  • You may not post replies
  • You may not edit your posts
