Results 1 to 3 of 3
Thread: Lets talk LED bulbs
  1. #1
    Join Date
    Oct 2005
    Location
    Chestermere, Alberta Canada
    Posts
    532
    Feedback Score
    1 (100%)
    Default Lets talk LED bulbs
    I am on Ebay and i am looking at LED bulbs to replace my tail light bulbs. Anyone done this and what is the best choice of bulb since there is a bunch out there?
    1988 Thunderbird Sport. No engine, no trans, turbocoupe disk diff with 3:27 gears, 31 spline axles and Cobra clutch packs, Turbocoupe front brakes.
    Bought this car back as an old project car.
  2. #2
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,143
    Feedback Score
    6 (100%)
    Default
    The brighter, the better...look for tower bulbs that are marked 5050 or higher. Also, you will need to install the inline resister for every bulb or else things won't work correctly. You'll probably need a new flasher as well.
    From what I'm told, these are about the best LEDs you can get:
    https://secure.cougarpartscatalog.com/plasma2.html
    Poke around on that site because you can get a set of 6 if need be.
    Also, you will want red bulbs with your car's red lenses...if you try to use white bulbs, they'll turn pink. Keep it red and you're fine.
  3. #3
    Join Date
    Oct 2005
    Location
    Posts
    532
    Feedback Score
    1 (100%)
    Default
    Plasma ones look good.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
