Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Non-start question
  1. #11
    Join Date
    Mar 2010
    Location
    Mount Juliet, TN
    Posts
    218
    Feedback Score
    3 (100%)
    Default
    Well, FWIW: Turned out to be the starter solenoid. Seems the neutral safety switch has been disconnected the entire 23 years I've owned the car and I never knew :O
    1986 Mercury Cougar XR-7 Turbo-charged 5-speed.
    Owned 22 years.
  2. #12
    Join Date
    Mar 2010
    Location
    Mount Juliet, TN
    Posts
    218
    Feedback Score
    3 (100%)
    Default
    Well...here we go again Evidently is was NOT the starter solenoid. Car refused to start again this morning on the way to work when I stopped at a market. Had to have her towed again. So - we've ruled out the neutral safety switch and the starter solenoid. Would the starter going bad cause this? When I depress the clutch and turn the key to start, all I get are radio, clock and gauges. I'm hearing NO sound, no click, no nothing like the car is even trying to start. I would think that if it was something with the fuel supply (pump, inertia switch, etc.) that she would, at least, try to turn over. It's like the ignition isn't even trying or I've turned the key to 'accessory.' Key cylinder and ignition switch were just replaced a few months ago and I've had no problems until this started last week
    Owned 22 years.
  3. #13
    Join Date
    May 2005
    Location
    Newmarket, ON, Canada
    Posts
    123
    Feedback Score
    0
    Default
    Next time it happens....grab your tire iron....lay down to the rear of the passenger front tire and give the starter a couple of wacks. Then try to start again. No start....give it couple more wacks and try again.
    The starter motor is likely good but either the Bendix (am I still allowed to call it that?) Is bad or the drive gear and or shaft is gunked up. This is assuming it's the old style starter.
    John
  4. #14
    Join Date
    Mar 2010
    Location
    Mount Juliet, TN
    Posts
    218
    Feedback Score
    3 (100%)
    Default
    Quote Originally Posted by Skunk View Post
    John
    THANKS! It's an '86 XR-7 so I think you may have hit upon an idea!! We had a '59 Chevy when I was growing up and we used to keep a ballpeen hammer handy to whack the solenoid when it would stick so, at least, I have experience with this maneuver :O
    Owned 22 years.
  5. #15
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,078
    Feedback Score
    2 (100%)
    Default
    Again, popping it with a screw driver would rule out both the ignition switch and the starter solenoid. You can just put the key in the run position (making sure its not in gear, or it will run you over or drive off without you) and stick a piece of metal acrossed the two big solenoid posts. If it starts, either the starter solenoid or ignition switch isnt working.
    Btw, it will spark, so don't wanna stick your face right down in there when ya do it. Might save ya from another tow truck though.
    Quote Originally Posted by jcassity
  6. #16
    Join Date
    Mar 2010
    Location
    Mount Juliet, TN
    Posts
    218
    Feedback Score
    3 (100%)
    Default
    Quote Originally Posted by Haystack View Post
    FINALLY figured it out. Something as simply as a loose wire going to the clutch switch which is explains why for several days the car would start if it could be moved a bit or towed somewhere All is now good! I HATE electrical problems so it AMAZING me that I love this car the way I do :O
    Owned 22 years.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
