Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
Thread: Brand new member - looking for advice on an upcoming purchase.
  1. #11
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,308
    Feedback Score
    4 (100%)
    Default
    Door window channel runs are no longer made so take that into consideration. You can find the dew wipes, door seals, and trunk seal but not the runs.
  2. #12
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,638
    Feedback Score
    17 (100%)
    Default
    The biggest thing is strut tower rust, torque box rust, and rocker rust. Anything bad costs $$$$ to fix, especially the strut towers. The strut towers aren't hard to repair but the engine has to come out most of the time to do it correctly.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  3. #13
    Join Date
    Sep 2017
    Location
    Wichita, KS
    Posts
    16
    Feedback Score
    0
    Default
    Gentlemen, thank you for all of the tips!
    I go to look at the car this weekend. Hopefully, it checks out good. If not, the search continues on, because I'm really thinking for what I am trying to accomplish, the Fox Thunderbird or Cougar is really where I want to be. I am also looking at Lincoln Mark VII's, but I think those can be a bit more tempermental, and I typically see those with pretty roasty interiors. I also understand a T5 swap in one of those is a little trickier...something about the hole in the floor not being quite in the right spot?
    Tim
    2003 Mercury Grand Marquis LS - For now!
  4. #14
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,638
    Feedback Score
    17 (100%)
    Default
    Mark VIIs are fine. I used to own one. The air suspension gets a bad rap but, really, it's stupid easy to fix. Heck replacing all the air springs and compressor is easier and often just as cheap as a coil spring swap. I would keep the air suspension in the Mark VII. Now the Teves II ABS system no. I'd ditch that if I planned on keeping the car. New parts are pretty much made of unobtainium now. Convert it to regular vacuum assist with a booster and master cylinder from a SVO Mustang (same brakes all around) and and adjustable prop valve or SVO Mustang/87-88 Turbo Coupe prop valve and you're good to go.
    Mark VII T5 swap: http://www.lincolnsonline.com/tech/00140.html
  5. #15
    Join Date
    Sep 2017
    Location
    Wichita, KS
    Posts
    16
    Feedback Score
    0
    Default
    Gentlemen, let me ask you another question.....
    How many of you daily drive your cars? I'd likely put upwards of 80 miles A DAY on this car when I drive it to work and back. Pretty reliable for the most part?
    Tim
  6. #16
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,638
    Feedback Score
    17 (100%)
    Default
    It should be fine. I could dd mine but I live in the salt belt, so no dice.
  7. #17
    Join Date
    Sep 2017
    Location
    Wichita, KS
    Posts
    16
    Feedback Score
    0
    Default
    Quote Originally Posted by thunderjet302 View Post
    That's awesome, it really is. My last 80's car required a full and complete build before being deemed "dependable".
    Tim
  8. #18
    Join Date
    Jul 2009
    Location
    Long Island NY
    Posts
    1,635
    Feedback Score
    0
    Default
    Welcome to the forum. I had a 87 XR-7 for about 2 years, and i will tell you to run your hands under the inside trunk area below the back window. All fox Birds and Cats are known for collecting gunk in the rear windshield channels and you can get rust in the trunk area. Pull the spare tire out too and feel the trunk matte for wetness or a mildew smell. Keep us posted on your purchase.
  9. #19
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,181
    Feedback Score
    2 (100%)
    Default
    I've been daily driving these cars for 14 years. My last one had 350k miles, original engine and tranny. Can't take credit for all of it though, i bought it at 290k miles or so. My current car is a 1986 tbird. I bought it at 131k miles in January and its sitting at 154k miles right now. Have a 200 mile drive planned in it tomorrow.
    For the aod, make sure the tv cable bushing is good, sometimes the radiator trans copper fittings leak, but they are a $5-10 thing at any auto parts store.
    You can daily these cars, i do pizza delivery in mine right now. You will have issues though. It's a 30 year old car and the parts are now starting to get scarce. Most common wear items are still available and there is a ton of parts compatibility between a bunch of other newer cars. You'll want a back up car incase issues come up, but they can be daily driven.
    My car has needed tires, and ignition switch and recently my seat back broke on the drivers chair. But I am really, really hard on my cars. I might do 20 or more deliveries a day, constantly getting in and out of the car, sometimes driving on dirt roads and randomly i drive up to 1000k miles a week freeway in addition to that
    Quote Originally Posted by jcassity
  10. #20
    Join Date
    Apr 2007
    Location
    kansas city mo.
    Posts
    7
    Feedback Score
    0
    Default
    Welcome to the forum. Check out Kansas City Craigslist 1985 Thunderbird , no rust.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
