Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: 88 TC aka Bad Decisions
  1. #11
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default
    Made some decent progress today, all the brake/fuel line clips came loose.
    -Pulled wheel well liners
    -Got the calipers pulled and hung
    -Dropped swaybar off the frame hangers
    -Broke the rear K member bolts loose
    -Broke the strut bolts loose
    Tried to drop the driver side front Kmember bolts, promptly broke the tabs off the nut plates. Got them turning with a breaker bar, but decided to let them soak in oil for a while and try it later. Or borrow a nut splitter.
    Passenger side I'm just going to cut through them via my engine bay access hole.
  2. #12
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,637
    Feedback Score
    17 (100%)
    Default
    The work isn't particularly difficult, once the engine is out. If you have a welder and the skills it's something that can be tackled at home. Now paying someone to do it is where it gets $$$, due to the labor costs.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  3. #13
    Join Date
    Aug 2017
    Location
    New York
    Posts
    19
    Feedback Score
    0
    Default
    Do the mustang floor pans fit these or do I need to just get metal and patch them in?
  4. #14
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default
    Zach you will need to patch them, the mustang floors are different. With that said, it's not a particularly difficult pan to create from sheetmetal if your existing floor is there to take good measurements from.
  5. #15
    Join Date
    Oct 2004
    Location
    Pasadena, MD
    Posts
    7,419
    Feedback Score
    7 (100%)
    Default
    Quote Originally Posted by thunderjet302 View Post
    Isn't that always the case
  6. #16
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default
    Managed to get the driver side Kmember bolts out, it was a battle. Pretty happy i can just cut the passenger side, cause that was zero fun.
  7. #17
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,637
    Feedback Score
    17 (100%)
    Default
    On the bright side the bolts are still pretty much the same diameter as when new. I've seen some very rusty K-member bolts that were only half or less of their original thickness.
  8. #18
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default
    I'm blown away by what LMR and 50resto charge for these crossmember bolts and j nuts, I understand they're special, but 200$ for four bolts and nuts?
    Looks like I'm getting some used ones haha.
  9. #19
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,637
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by Sancho View Post
    Jebus. Yeah just eBay it. I've seen all 6 K-member bolts from a Fox Mustang listed for $50-100.
  10. #20
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,181
    Feedback Score
    2 (100%)
    Default
    A grade 8 or better hardware store bolt wouldn't cost more then $15... you car cutting and replacing the entire area. I wouldn't be worried with originality...
    Quote Originally Posted by jcassity
Posting Permissions
  • You may not post replies
  • You may not edit your posts
