Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 88 TC aka Bad Decisions
  1. #1
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default 88 TC aka Bad Decisions
    Some background, bought car in 2004ish, it's been a Michigan car it's entire life and as such is rusty as heck.
    What's been done:
    -Driver floor pan replaced from kick panel to rear well
    -Gas tank mounts rebuilt
    -Front window frame rebuilt and windshield actually attached to body
    -Rebuilt motor and transmission
    Went to pull the motor the other night and found the passenger shock tower attached via hopes and dreams. Spoke with scottrodfab and ended up ordering a repair section, mostly because I'm too stupid to declare defeat after dragging this thing around for a bit over a decade. Tomorrow I'm pulling the motor to see what I'm up against.
  2. #2
    Join Date
    Apr 2016
    Location
    Mi. 48182
    Posts
    315
    Feedback Score
    0
    Default
    Wow you got some work to do there! Where in Mi are you?
    Brian R.
    88 2.3t Ranger
    83 TC gt40p motor,Vortech,TFS1 cam,long tubes,MS PnP,T5,8.8,17x9 Cobra 17s
  3. #3
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default
    I'm north of Detroit, Great Lakes crossing area.
    Got the motor pulled tonight with my 6 year olds help, had the fuel feed line hang up but it came loose with some persuasion. Separated the trains/bell and got the old motor supported off to the side.
    Got a better gander at the frame rust, and it's a bit bigger than my patch piece from scottrod. The inner tower pieces will be an invaluable time saver though on the fabrication side. Current plan is to cut somewhere halfway up the kickup and rebuild the rail until the rear stabilizer bar bracket
  4. #4
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,490
    Feedback Score
    17 (100%)
    Default
    How in the hell did the car not fall apart?
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  5. #5
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,388
    Feedback Score
    14 (100%)
    Default
    Like he said.......hopes and dreams. Hey, if Jerry can do it, you can too.
    '84 Mustang, work in (sloooooooow) progress...
    '87 Stang notch
    1994 Ford F150 Flareside
    1997 Explorer V8 conversion (in progress)
    1998 Explorer 5.0
    and a couple of tractors. Ford, of course.
    FORD power, for life!
  6. #6
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default
    It's really a feature, think about how much work it is to drop the cradle. This body has optimized its geometry to the point where the cradle can be removed from either side of the frame rail.
  7. #7
    Join Date
    Apr 2016
    Location
    Mi. 48182
    Posts
    315
    Feedback Score
    0
    Default
    I bought a TC parts car years ago that was rusted so bad in that spot the hood was only thing holding the car up! I popped the hood and the strut pushed the hood up and broke the safety catch on the hood and the whole car dropped 4"! And I drove it 5miles to my house. lol
    Brian R.
    88 2.3t Ranger
  8. #8
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,490
    Feedback Score
    17 (100%)
    Default
    That whole area is kind of a piss poor design. All the gaps let water in and it just sits there. When the area is repaired it makes sense to just weld all the seams solid, so it's harder for water to intrude.
  9. #9
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default
    Found a bit of rust on the driver side rail as well, but it's small time compared to the passenger side. I do think I'm going to just seam weld it all together.
    Went through the scrap bin at work and pulled a workable pile of 12/16ga sheet steel, should be enough to make a solid first pass. Little bummed I moved the car into the middle bay in my garage, I can't reach the car with my tig welding leads so may need to borrow a small mig for the bulk of this.
    Dug this out of my pile of books, too bad PB sucks. Would love to share this in full resolution.
  10. #10
    Join Date
    Oct 2004
    Location
    Pasadena, MD
    Posts
    7,405
    Feedback Score
    7 (100%)
    Default
    I've been using Flikr with good results so far. If you have and old Yahoo account, just use that to sign in. Just have to be slightly crafty with the codes.
    I actually scrapped a TC with rust half as bad as yours in the same area. You're a bad bitch to even attempt trying to get that back together.
    It's Gumby's fault.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
