Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: 351W (427W) w/Canton oil pan is hitting steering rack
  1. #21
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,046
    Feedback Score
    34 (100%)
    Default
    You should see the extra washers by Sat.
    Long live the 4-eyes! - '83 Tbird Turbo
  2. #22
    Join Date
    Nov 2004
    Location
    So. NH
    Posts
    2,014
    Feedback Score
    1 (100%)
    Default
    Quote Originally Posted by Chuck W View Post
    Awesome, thanks
  3. #23
    Join Date
    Nov 2004
    Location
    So. NH
    Posts
    2,014
    Feedback Score
    1 (100%)
    Default
    I did indeed get the new washers yesterday. Thank you very much. I added 2 to the passenger side mount and now there's clearance between the rack and oil pan! Probably make the driver's side the same after I get this beast running.
  4. #24
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,046
    Feedback Score
    34 (100%)
    Default
    Not a problem. Hope you get it running soon.
  5. #25
    Join Date
    Nov 2004
    Location
    So. NH
    Posts
    2,014
    Feedback Score
    1 (100%)
    Default
    It's fighting me at every turn. Yesterday I had to remove every Earl's straight AN fitting (4 total) and replace them with Russel brand. After spending 45 minutes trying to get one of those fittings to properly cut into the Teflon tubing, I finally decided that I don't trust the engineering behind these when used with an inner hose (braided stainless exterior) that was too hard/slippery to slice axially with their "cutter" ring (it's just a sharp edge soft aluminum ring, no serration.) Glad Pep Boys sells these fittings and they currently have a 30% discount on many items which made them the same price as online (Summit.) This was one problem of several causing me to fritter my time away, though I could only work so hard with 100 degree "real feel" soupy air. Oh, well. At least it wasn't snowing.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
