Results 1 to 7 of 7
Thread: 95 HO into 88 V6 T-bird
  1. #1
    Join Date
    Jul 2017
    Location
    Butler
    Posts
    6
    Feedback Score
    0
    Default 95 HO into 88 V6 T-bird
    Hey guys I thought I'd start a new thread with some of the issues that I'm having with my engine swap. I have the engine in the car with all the connections hooked up. I have an engine harness from an 87 5.0 cougar trying to match to the body of an 88 V6. The connections don't match very well, and I need some input on what I need to do from here. If anyone is familiar with which wires to hookup or leave disconnected, please let me know.
  2. #2
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    Quote Originally Posted by LastThunderfox View Post
    Should be color for color...
    AFAIK, there is no reason to leave anything disconnected... Some things would be deleted on a Turbo Coupe...
    BTW the '88 5.0 harness is plug & play for install into a '88 3.8, there are several differences in '87 to '88...
    My other rides (that actually do run & drive)
    1969 Fairlane Cobra 428CJ 4-Speed << New 49th Birthday Picture
    1972 Comet GT - 306 C4
  3. #3
    Join Date
    Jul 2017
    Location
    Butler
    Posts
    6
    Feedback Score
    0
    Default
    I'm seeing a couple connectors that need adjusted. Please correct me if I'm wrong-
    1) there are the black and grey connectors by the brake booster (every one needs repinned). There are also 2 single wire connectors as well, don't know if I should ignore them (white/red and black/orange)
    2) the grey rectangular connector under the coil (found that the oil and temp wires are in this one today)
    3) the connector next to the ecu has matching wires apart from the body having an extra pink/black wire
    I got the 87 harness because that is what I was able to find in the junkyards near me. I didn't see the differences until I started hooking things up.
  4. #4
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,210
    Feedback Score
    2 (100%)
    Default
    The v-6 harness might actually be a closer match then the 87 v-8.
    Quote Originally Posted by jcassity
  5. #5
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    Quote Originally Posted by Haystack View Post
    C'omon, a batch fire V6 isn't going to be closer than any SEFI 5.0 harness... Well maybe the OBD-II version in my '96 F-150...
  6. #6
    Join Date
    Jul 2017
    Location
    Butler
    Posts
    6
    Feedback Score
    0
    Default
    All right, this is what I came up with, please correct me if I'm wrong-
    Oil pressure - white / red
    Temperature - red/ white
    Ground- black
    Pin 30- brown/ White
    Pin 46- black /white
    Pin 17 tan
    Tach- Dgreen /yellow
    A/C green /purple
    O2- grey/yellow
    Start- red/blue
    Vpwr/Run- black /yellowmolested and red/green
    Vss+ Dgreen/white- needs added to harness (in grey connector )
    Vss- orange /yellow -needs added to harness (in grey connector)
    (The stand alone connectors seem to be left unconnected)
    Pin 19 (fuel pump check)- pink/black
  7. #7
    Join Date
    Jul 2017
    Location
    Butler
    Posts
    6
    Feedback Score
    0
    Default
    Well, I test drove it tonight. Everything seems to be working. I didn't do anything with the black /white Pin 46, I just wired it like I posted previously. I did hook up my starter neutral safety switch by connecting the two wires (red/blue, white/pink) at the transmission, then splicing my clutch pedal switch into the white /pink wire behind the climate control. So now, I'm going to try to go to the UMTR race this Sunday, and hope for low 15s
Posting Permissions
  • You may not post replies
  • You may not edit your posts
