Results 1 to 9 of 9
Thread: Hood Swap from plane Jane to TC w/scoops
  1. #1
    Join Date
    Sep 2017
    Location
    Toms River, NJ
    Posts
    1
    Feedback Score
    0
    Default Hood Swap from plane Jane to TC w/scoops
    I purchased an 87 TC hood w/scoops on ebay, it arrived by Grayhound in excellent condition.
    Has anyone swapped out there plane Jane hood for a TC hood w/scoops and having a 5.0 CFI with the round air cleaner? I still want to keep the scoops functional, deleting the 2.3 air ducting under the hood. Any interference with fan shroud or air cleaner? Any mods to the air cleaner? any suggestions will help, Thanks
  2. #2
    Join Date
    Sep 2012
    Location
    N.C.
    Posts
    518
    Feedback Score
    6 (100%)
    Default
    The TC hood swap has been done by a lot of the guys on here. Shouldn't have any problems. You didn't say what year your car is but if it is a "4-eye" I'm pretty sure you can also swap in 87/88 Tbird hood hinges/springs. This will allow you to do away with the hood prop rod. Good luck and welcome... Great guys here with lots of knowledge on these cats.... Oh yeh, the ducting under the TC hood is easily removed.... Ray.
    87 Tbird LX w/Factory floor shifter 3G upgrade. Tinted Windows...85 Mustang GT steering wheel(non-cruise) 17'' Saleen SC style wheels,Front/Rear TC sway bars/poly bushings & Mustang GT steering rack...'05 Mustang V6 springs...93 Cobra MC & booster, MM adjustable C/C plates, Work In Progress....... ( On The Shelf---HO computer, 19lb injectors, HO cam, BBK headers, Explorer Intake, Cold Air Intake ,Phantom Gauges, Stinger stainless exhaust pipes )
  3. #3
    Join Date
    Apr 2009
    Location
    Ohio
    Posts
    1,302
    Feedback Score
    0
    Default
    I ran one on my 83 CFI 5.0 with no clearance issues.
    CoogarXR
    1986 LTD Wagon
    1985 Cougar XR-7
  4. #4
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,616
    Feedback Score
    17 (100%)
    Default
    I'd figure out the drainage situation, unless your engine likes drinking water
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  5. #5
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,169
    Feedback Score
    2 (100%)
    Default
    I ran one for four years and about 80k miles on a 86 5.0 .Never blocked off the vents. Its not much different then driving through a puddle.
    Make sure the motor mounts are good. Mine broke and i broke both scoops.
    Quote Originally Posted by jcassity
  6. #6
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,616
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by Haystack View Post
    OP mentioned working "ram air", hence my keeping the water out comment.
  7. #7
    Join Date
    Apr 2016
    Location
    Mi. 48182
    Posts
    316
    Feedback Score
    0
    Default
    Im not sure how you would hook the scoops up to the snorkels on the air cleaner base but you could make a pan that sits in place of the factory air cleaner that seals to bottom of hood with foam. It would be pretty big to catch the hood scoops but would work.
    Brian R.
    88 2.3t Ranger
    83 TC gt40p motor,Vortech,TFS1 cam,long tubes,MS PnP,T5,8.8,17x9 Cobra 17s
  8. #8
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,169
    Feedback Score
    2 (100%)
    Default
    Quote Originally Posted by thunderjet302 View Post
    My bad. Sorry
  9. #9
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,418
    Feedback Score
    15 (100%)
    Default
    the 1990 ford bronco and all the other late 80's / early 90's would have the duct work you need.
    ive studied this for avery long time and fit tested to some degree the parts.
    check out any of the pick up trucks
    once you look under the hood of the pick up's you will see what i mean.
    i would suggest you dont throw away the ducting on the tc hood. its useful for getting to the next step of air flow.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
