Page 12 of 12 FirstFirst ... 289101112
Results 111 to 119 of 119
Thread: Seat upgrade ... attempt #2 ...
  1. #111
    Join Date
    Sep 2012
    Location
    N.C.
    Posts
    501
    Feedback Score
    5 (100%)
    Default
    Awesome!! Looking forward to your input on the TMI foam so far as comfort. Can’t wait to see them in the car. Very detailed thread. Thanks .
    87 Tbird LX w/Factory floor shifter 3G upgrade. Tinted Windows...85 Mustang GT steering wheel(non-cruise) 17'' Saleen SC style wheels,Front/Rear TC sway bars/poly bushings & Mustang GT steering rack...'05 Mustang V6 springs...93 Cobra MC & booster, MM adjustable C/C plates, Work In Progress....... ( On The Shelf---HO computer, 19lb injectors, HO cam, BBK headers, Explorer Intake, Cold Air Intake ,Phantom Gauges, Stinger stainless exhaust pipes )
  2. #112
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,234
    Feedback Score
    4 (100%)
    Default
    Cannot wait to hear if this solves the weird height issue with the Corbeaus.
  3. #113
    Join Date
    May 2016
    Location
    Lancaster, PA
    Posts
    208
    Feedback Score
    1 (100%)
    Default
    Awesome!! Looking forward to your input on the TMI foam so far as comfort. Canít wait to see them in the car. Very detailed thread.
    Thanks. They turned out pretty nice and feel good, but the true test will be getting them in the car ... hopefully over the weekend with any luck.
    I'll definitely keep you posted, I owe you some measurements as well.
    Getting the passenger seat ready to go in. Here are some shots of the back seat as well. I'm monkeying around with the center armrest a little, thus why it's missing in the one shot.
    Attached Images Attached Images
  4. #114
    Join Date
    Nov 2005
    Location
    Louisville, KY
    Posts
    361
    Feedback Score
    3 (100%)
    Default
    I might have missed it, but where did you find the seat belt buckle sleeves? Are the Mustang equivalent close enough to use on T-bird / Cougar?
  5. #115
    Join Date
    May 2016
    Location
    Lancaster, PA
    Posts
    208
    Feedback Score
    1 (100%)
    Default
    Quote Originally Posted by Drewstang View Post
    The seat belt buckle sleeves ... believe it or not ... are actually my OEM original ones. They're not perfect, but they are still in really good shape. You can use Mustang ones, while not identical, they will get you by. Eric has a write up on this here: http://www.coolcats.net/restoring/seatbelts.html
  6. #116
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,498
    Feedback Score
    17 (100%)
    Default
    Those came out really nice! Great job. Can't wait to see them in the car.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  7. #117
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,090
    Feedback Score
    6 (100%)
    Default
    Quote Originally Posted by 85CougarCobra View Post
    You got pretty lucky with the originals, Matt. Glad to see you reused them. Seats came out awesome!
    I have Mustang sleeves on my car. They do work well but you have to crank down the Torx bolts really tight to keep them from flopping all over. They also hold paint very, very well. Only thing I don’t like, aside from not being technically correct, is that they’re all made in furrin’ countries. One of these days I hope someone in North America can reproduce the correct sleeves for us.
  8. #118
    Join Date
    May 2016
    Location
    Lancaster, PA
    Posts
    208
    Feedback Score
    1 (100%)
    Default
    Quote Originally Posted by EricCoolCats View Post
    Thanks! Yeah, my originals are still going strong, but they do have splits in them on parts of the seams ... only a matter of time I suppose. I'm afraid to look at them wrong! I bought Mustang ones for the Corbeaus but once I ditched that plan and the 87-88 vintage power seat tracks, I went back to the 83?-86 power seat tracks and my stock seat belts/sleeves.
  9. #119
    Join Date
    May 2016
    Location
    Lancaster, PA
    Posts
    208
    Feedback Score
    1 (100%)
    Default
    Installed the seat back and passenger seat. I have a bit of a mess with some other interior work ongoing, but getting closer ...
    Unfortunately, it will be little time before I can actually "test" anything. Car wouldn't start a few weeks ago, diagnosed a fuel pressure/pump issue, dropped the tank to find a slit in the fuel hose inside the tank that is connected to the pump, so need to take care of all of that "fun" stuff as well ... easy enough, but a PITA at the same time.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
