Results 1 to 5 of 5
Thread: Best Fit Electric Fan
  1. #1
    Join Date
    Apr 2016
    Location
    Columbiana, Ohio
    Posts
    126
    Feedback Score
    0
    Default Best Fit Electric Fan
    I've read quite few posts on the forum regarding electric fan conversions. It appears Taurus, Contour, Fusion, Escort and aftermarket fans have been used with success. Is there a particular fan and shroud assembly that fits the shape of our radiators better than another? Taurus fans seem popular however, they can differ somewhat depending on the model year based on the two Taurus's I have owned. My application is a 5 liter/AOD w/air.
    Appreciate any advise as I want to avoid a major fab project.
    1986 Thunderbird Elan 5.0 EFI AOD, 3.73:1 SN95 rear, 17" Mustang Bullitts w/Firestone WO Indy 500's. Future plan: 349 stroker, C9 block, forged dish pistons, Scat 9000 crank, 4340 I beam rods, ARP head/main studs, ported explorer intake, 1.72 CC RR, Vortech V2 supercharger, Mr. Freeze Meth Inj, intercooler, TFS 190 11R CNC heads (66CC), BBK shorties with 2.5" duals, 4R70W Transmission, Taurus fan.
  2. #2
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,297
    Feedback Score
    4 (100%)
    Default
    Mark VIII or Taurus fans are both good options. I have the Mark VIII with a DCControl on both my Bird and the Coupe and it works really good. You will have to trim the shroud and make some tabs to hold the fan in place. As for the Taurus a couple of my buddies have that one with the DCControl and it too works really good.
    http://www.dccontrol.com/constant_te...ontrollers.htm
    You want the fan off of an early 90's to 95 3.8 V6 Taurus or off of a 5-speed 89 to 95 SHO as they have the same fan. The Mark VIII and Taurus fans are getting hard to come by and can be expensive.
    Another really good option is a twin fan setup from a V6 Contour/Mystique. I has to be a V6 car and about the only real good way to control a dual fan is with something like a DCControls unit. People will mouth about having to wait months for a controller but I literally ordered one to replace the 10 year old unit on my Coupe last year and got it in three weeks.
  3. #3
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,169
    Feedback Score
    2 (100%)
    Default
    Id go with a dual motor fan. With the waterpump and pulley sticking out so far, any singled motor fan will be pretty close. My taurus two speed fan was only a fingers width away from the pulley.
    With a dual motored fan, you just wire one fan with a relay to be on with the ignition and then use a regular controller for the other fan.
    Quote Originally Posted by jcassity
  4. #4
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,505
    Feedback Score
    135 (100%)
    Default
    I use a single fan Taurus piece. Never had an issue, and the temps here get over 100 degrees every year. Got the whole assembly brand new from Ebay for less than $70, and the shroud covers the whole face of the radiator.
    '88 Sport--T-5,HURST shifter,TMoss GT-40 intake,Ed Curtis cam,Trick Flow heads,Scorpion rockers,70mm t-body,3G,mini starter,Taurus fan,BBK headers,O/R H-Pipe, Flowamaster 40's, deep and deeper Cobra R wheels,Mass Air, Mass Air and 24's,8.8 with 3.73's,140 mph speedo,Mach 1 chin spoiler,SN-95 springs,CHE control arms,aluminum drive shaft and a lot more..
  5. #5
    Join Date
    Apr 2016
    Location
    Columbiana, Ohio
    Posts
    126
    Feedback Score
    0
    Default
    Thanks, guys. Gives me some options.
    I'm waiting on my 3g alternator from Rock Auto and the fan and a new master cylinder will be next.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
