Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: reproduction 93 Cobra wheels
  1. #11
    Join Date
    Aug 2014
    Location
    camdenton, mo
    Posts
    187
    Feedback Score
    1 (100%)
    Default
    Quote Originally Posted by thunderjet302 View Post
    10 inch discs up front, 10 inch drums in the back (88 XR7 8.8 axle). So yes, the stock 14 inch wheels still fit.
    At some point I'll probably upgrade to 11 inch front brakes. I just need to pick up some 87 to 93 V8 Mustang front spindles.
    if you want my set of v8 spindles you can have them for the price of shipping
  2. #12
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,490
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by Aerocoupe View Post
    I see your point on the 16" vs. the 17" but you need to address those anemic brakes before you go any faster. Ask Vinnie how he likes his 11" fronts and TC rear brakes and after talking with him do your brakes first and then start looking for wheels.
    So here are the original 93 Cobra Wheel specs:
    1993 Cobra Wheel Specs:
    RH: F3ZZ-1007-A
    LH: F3ZZ-1007-B
    17x7.5
    Offset = 1.61" or 40.9mm
    Backspace = 5.9"
    Bolt Pattern = 4 X 4.25"
    LMR's Wheels:
    RH: LRS-1007RSR
    LH: LRS-1007RSL
    17x8.5
    Offset = 26mm
    Backspace = 5.72"
    So LMR's Cobra wheels will not fit a 93 Cobra due to that car using the TC rear which is 0.75" wider per side than a stock Fox Mustang 8.8 rear. The front rotors on a 93 Cobra a specific to that car as well in that the rotor hats are 0.75" wider than a stock 87-93 V8 car rotor. This was done so that all the wheels had the same offset so they could be rotated.
    So with all of that said it looks like the LMR wheels have about the same backspacing however the rim will move outward about an inch. If you compare the two wheels with a 245/40/17 tire then you will actually only move the outer wall of the tire about 0.6" outward. This makes sense on an 87-93 Mustang being their rear end and front rotor hats are about 0.75" narrower than the Cobra. Figured all this out here:
    https://www.rimsntires.com/specspro.jsp
    Hope that helps.
    So it looks like the LMR 93 Cobra reproduction wheels will stick out past the fender lip? Screw that noise.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  3. #13
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,234
    Feedback Score
    4 (100%)
    Default
    I would say no. The reason I say that is on a 93 Cobra the front rotor hats are 0.75" wider than the rotors on our cars. So if if you were to install a 93 Cobra wheel on the front of one of our cars it would move inward 0.75".
    As for the rear, I believe these wheels will fit for these reasons:
    1) I have seen the TC Snowflake wheels on a Fox Mustang
    2) Snowflake wheels fit our cars
    3) LMR Cobra Wheels fit a Fox Mustang
    So play around with known wheels (diameter, width, offset, etc.) that fit our cars on that link I posted and see what you think. I'm pretty sure that we have the room for these wheels but I have not bolted a set up so I'm not 100% sure.
  4. #14
    Join Date
    Aug 2014
    Location
    camdenton, mo
    Posts
    187
    Feedback Score
    1 (100%)
    Default
    Eh, I picked up some real nice ROH wheels that fit perfect on a mustang, but rub on the lip of my fenders just barely.
  5. #15
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,234
    Feedback Score
    4 (100%)
    Default
    Front or rear? What's the diameter, width, and offset? What size tires?
  6. #16
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,388
    Feedback Score
    14 (100%)
    Default
    Kind of a bit off topic, but I did a spare set of 'flakes onto an '89 LX Stang (that's a 4 banger for you non Stang folk), and they filled out the wells nicely. Of course the tires were 225/60's, so...
    Looked good too. What's even better is turbines on an Escort GT ('87). Very sexy.
    /thread derailment..
    '84 Mustang, work in (sloooooooow) progress...
    '87 Stang notch
    1994 Ford F150 Flareside
    1997 Explorer V8 conversion (in progress)
    1998 Explorer 5.0
    and a couple of tractors. Ford, of course.
    FORD power, for life!
  7. #17
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,490
    Feedback Score
    17 (100%)
    Default
    Someone here has a set of LMR reproduction 93 Cobra wheels. I forget who but I wonder how they fit. If I remember they are on an 87-88 Thunderbird.
  8. #18
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,388
    Feedback Score
    14 (100%)
    Default
    I know who you're talking about, but can't remember his name. He lives in Indiana, IIRC. Grey Thunderbird, 5.0...
    '87 Stang notch
    1998 Explorer 5.0
  9. #19
    Join Date
    Sep 2012
    Location
    N.C.
    Posts
    501
    Feedback Score
    5 (100%)
    Default
    I think it's"50tbrd88"..... He has the replicas in chrome on his car... I have considered these wheels in the past. Saw them on a dark blue 87 TC and they looked great.
    87 Tbird LX w/Factory floor shifter 3G upgrade. Tinted Windows...85 Mustang GT steering wheel(non-cruise) 17'' Saleen SC style wheels,Front/Rear TC sway bars/poly bushings & Mustang GT steering rack...'05 Mustang V6 springs...93 Cobra MC & booster, MM adjustable C/C plates, Work In Progress....... ( On The Shelf---HO computer, 19lb injectors, HO cam, BBK headers, Explorer Intake, Cold Air Intake ,Phantom Gauges, Stinger stainless exhaust pipes )
  10. #20
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,490
    Feedback Score
    17 (100%)
    Default
    i think that's him. I'll have to drop him a PM.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
