Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: OEM Camber Plate Pop Rivet Settings
  1. #11
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,779
    Feedback Score
    7 (100%)
    Default
    The factory plates won't even get you close. Ask me how I know.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  2. #12
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,075
    Feedback Score
    34 (100%)
    Default
    Quote Originally Posted by 87tbird_org_owner View Post
    Metal to metal will slip unless it is serrated. So it's better to play it safe and keep the rivet feature than be sorry from a pot-hole hit or just the car vibrations.
    I have NEVER had a strut mount slip on one of these cars in the past 25+ years I have been messing with them. Be it stock plates or aftermarket CC plates.
    Long live the 4-eyes! - '83 Tbird Turbo
  3. #13
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,264
    Feedback Score
    4 (100%)
    Default
    Been running the Maximum Motorsports CC plates on my 93 coupe for over 17 years and on the Bird for about the same amount of time and never a slip. These CC plates are put on all out road race cars with radical alignments and do not slip unless the poor putz did not assemble or torque them correctly. Here is a shot of them on my Bird:
    You can see that the bolting passing through the holes in the strut tower all have a slotted adjustment from right to left to compensate for the camber you want to achieve. The upper plate (the one you see on top of the strut tower) can be flipped one way to produce a maximum amount of negative camber (racing) and then flipped the other way for a slight amount of negative camber (street). You will also notice that the top plates have front to rear slots in which you see mine are maxed out to the rear. This is to produce the maximum amount of caster as these cars need all the caster they can get to help with putting more negative camber into the loaded tire when cornering. I have corrected for the bumpsteer on both of my cars due to the caster being maxed out as well as how low they are but on a typical street car lowered an inch or two this is not an issue.
    Read MM's installation instructions as they do a really good job of explaining the how's and why's.
  4. #14
    Join Date
    Aug 2015
    Location
    Lansing, IL
    Posts
    37
    Feedback Score
    0
    Default
    Quote Originally Posted by Aerocoupe View Post
    Do you mind saying what your caster and camber settings are? From the photo submitted it looks the camber is very negative going by the position of the strut shaft. Also can tell your caster setting is at the max negative is this also correct?
  5. #15
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,779
    Feedback Score
    7 (100%)
    Default
    If he can't, I will. After my drop, I was able to use the factory plates to go from -2.8 to -2.1. After the MM C/C plates, I was able to set the camber to factory spec at -0.75. I was also now able to dial in more caster than factory, which is highly desirable. My caster is +4.5, with no cross caster. I can do these things myself because I'm an ASE Master mechanic and I naturally have access to the alignment rack. If your situation is different, you'll need to explain what you have and what you need directly to the tech who will be doing your alignment so that you are completely understood. Service advisors are likely to not get what you're asking for.
    I would highly recommend using my alignment specs. Of course, adjusting camber and caster will make it necessary to reset toe, so be a nice guy and make sure your jam nuts are free, maybe spray some penetrating oil before hand.
    Last piece of advice, see about sitting in the car while the alignment is being done. This will help ensure that the car is set to spec considering your presence in the car.
  6. #16
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,264
    Feedback Score
    4 (100%)
    Default
    Alignment specs are in the MM instructions for street and race. I took the installation instructions to the alignment shop (Firestone) and the tech put it on the numbers for the street spec. MM's specs read as follows:
    ALIGNMENT RECOMMENDATIONS
    If you wish, you can simply have your car aligned to Fordís
    specifications:
    We recommend that caster be set to 4.5 degrees positive
    for street cars - but do not adjust the plate beyond the
    halfway point without special attention to bumpsteer
    detailed below. For race cars we recommend that the
    caster be set to 6 degrees positive, or at the limit of
    adjustment on the plate - with mandatory attention to
    bumpsteer. The Mustang responds favorably to increased
    positive caster. The reason: The more positive the caster
    setting, the more negative camber the loaded tire will gain
    while cornering.
    We recommend that camber be set to .5 degree negative
    for street cars, never positive as Ford allows. For race cars
    we recommend 1.5 to 2.5 degrees negative camber. Some
    cars/drivers need more negative camber for optimum
    handling and tire wear. Keep an eye on your own tire wear
    and make adjustments as necessary.
    We recommend setting the toe to the factory spec of .5
    degree toe-in for street use. For race cars we recommend
    .5 degree toe-out.
    So basically I am running 4.5 degrees of positive caster, 0.5 degrees of negative camber, and 0.5 degree of toe-in. And I am not an ASE tech but I did stay in a Holiday Inn last night (sorry Foe could not resist).
    With that being said I think that Foe and I are really happy with the CC plates and the alignment specs so jump in head first and buy a set.
  7. #17
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,779
    Feedback Score
    7 (100%)
    Default
    The only reason for me to claim my credentials was to explain how and why I have direct access to an alignment rack. I, too, followed MM's guidelines on alignment, but decided that the factory camber was better. I also found that +4.5 caster was about the maximum I could get from them.
  8. #18
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,264
    Feedback Score
    4 (100%)
    Default
    Meant for it to come off as kidding around man. You are a great source of info and I always enjoy your posts.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
