Results 1 to 5 of 5
Thread: Windshield and Rear Window Trim restore - DIY??
  1. #1
    Join Date
    Apr 2005
    Location
    NW Ohio
    Posts
    91
    Feedback Score
    0
    Default Windshield and Rear Window Trim restore - DIY??
    Hey everybody - I've been searching for info on removing/repainting the metal trim that goes around the windshield and rear windows of my '87 Cougar, but haven't found anything. Mine are still in great shape, but the black paint is just starting to come off/fade, so it just needs sprayed. I asked a small town body guy about it once, and he said he wouldn't touch it - he would rather have a glass guy do it to be sure that the trim didn't get bent up in removal. I was thinking about removing the trim myself and just spray-painting it, but this encounter has me worried that I'll bend it all up in the process.
    Has anyone removed/replaced this metal trim? Were you able to keep from bending/kinking it in the process? Did you purchase any special tools that helped? Or would I just be better off leaving this job to the professionals?
    Thanks!
  2. #2
    Join Date
    Dec 2007
    Location
    ONTARIO CANADA
    Posts
    450
    Feedback Score
    0
    Default
    I was afraid of removing the trim as well. What I did, was painstakingly mask around all the pieces with green masking tape wiped down the trim with lacquer thinner and apply SIM trim paint. The result was impressive especially since my trim was stainless to start with. Since your trim is already black, you would have no problem.
    84 COUGAR/88HO, 1.7RRs, performer RPM,700DP, equal length shorties, stainless EXH ,T-5,Hurst pro-billet, KC clutch, 8.8/ 4.10s, line-lok, bla ,bla, bla.
    71 COMET/289,351w heads, 12.5 TRWs, 750DP, Liberty TL, 9"/6.00s, 11.9x @112 , bla,bla,bla.
    Never shoot your mouth off, unless your brain is loaded! ....I may get older, but I'll never grow up!....If you're not laughing, you're not living!
  3. #3
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,022
    Feedback Score
    6 (100%)
    Default
    ^ This. It's a pain but it's worth the effort if you don't want to remove the trim.
    Otherwise, an auto glass repair shop should be able to pop the trim pieces out for you, for minimal charge. Same for reinstalling them. There is a special removal tool that's kinda scary to use...that's why I always let the glass shop do the removal for me.
  4. #4
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,060
    Feedback Score
    16 (100%)
    Default
    In a few weeks my Thunderbird is getting painted. The window trim is the one trim item I'm letting the body shop remove. I don't want to screw the pieces up as they are pretty much made of unobtanium now.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  5. #5
    Join Date
    Apr 2005
    Location
    NW Ohio
    Posts
    91
    Feedback Score
    0
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
