Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Need info about WOT cutout relay
  1. #21
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,814
    Feedback Score
    7 (100%)
    Default
    Last one, almost ready to go on the car.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  2. #22
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,814
    Feedback Score
    7 (100%)
    Default
    Ok, I think I've got a way to have everything I want. Yes, that's a dp3t double pole triple throw switch (good for you for catching that). Positions left to right are manual, off, auto. The weirdly shrunken looking relay in the bottom right is for the cutouts.
    Here's what that looks like
  3. #23
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,419
    Feedback Score
    15 (100%)
  4. #24
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,814
    Feedback Score
    7 (100%)
    Default
    I'll have to go back to the datasheet to answer that. I haven't wired it yet, too many irons in the fire.
  5. #25
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,814
    Feedback Score
    7 (100%)
    Default
    Update.
    Today I blew the dust off this project and cut my H-Pipe, then welded in the flanged pipes it appears I fabbed 2 WHOLE YEARS AGO. I mounted up the TB's and as expected, they leak just a tiny bit around the plates. I don't care about that, but what I DO care about, is that if exhaust is flowing through them at all times in ANY measure, they're going to run hotter than I wanted. This whole thing may just self destruct; but if it doesn't, I'll try to start wiring up simple controls I can operate while driving, before going on to build the integration I've planned on from the beginning. At least I've managed to move my little experiment onto the vehicle. Finally.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
