Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Need info about WOT cutout relay
  1. #11
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,496
    Feedback Score
    15 (100%)
    Default
    I like some of the stuff Foe plays around with,, im not so embarrassed now to post up my latest idea.
    something tells me you would be better off with a vac actuated check valve,,, it would be set to be open the amount you want for normal running but the door would pull open when there is no or little vac by a spring assisted lever.
    im just makin this stuff up as I go.
    so,, what the heck are you planning to achieve with this?
    quiet "pass inspection car" but a loud hard core sound when you want to intimidate the other guy?
  2. #12
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,496
    Feedback Score
    15 (100%)
  3. #13
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    We don't have inspections here. I have a 2.5 inch non cat H-Pipe, but a 2 inch dynomax turbo cat-back. I like the cruise sound, but with my build, I start running out of flow around 4k. At WOT, these will open to uncork the restriction and sound great, but ultimately let me keep my mellow, drone-free cruise sound. Active exhaust, for the win. This is done on new Corvettes and the GT350s, and the Hellcats; why not me?
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  4. #14
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,496
    Feedback Score
    15 (100%)
  5. #15
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    Quote Originally Posted by jcassity View Post
    ,, oh and when you pick heat or AC, the wot is in play.
    I'm pretty sure WOT cutout is always active. Once I pull her out for the spring, I'll verify. Right now, it's stored 50 miles away.
  6. #16
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    NOW I'm excited. I've discovered that the flanges I need to have made are dimensionally identical to 2.5" T3 turbo outlet flanges. I CAN JUST BUY THEM!
  7. #17
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    Update. WOT cutout, at the moment, is non-feasable. The relay is grounded (on) the moment you turn on the ignition and stays on until AC is requested. It function like a backwards AC clutch relay. I could fake a constant AC request, and the valves would cycle open at startup a second or two then close, but that would effectively also either disable the AC clutch or force me to install some sort of manual interrupt in the circuit. I'll still go forward using a 3 position switch for it (Off, Auto, Manual On), and I'll add the active control when I figure it out. I considered a nitrous WOT switch, but that's my low-tech backup plan.
  8. #18
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,656
    Feedback Score
    0
    Default
    How about using the n/c contacts of a relay to activate the cutout?
  9. #19
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    So, I've been moving forward, here are some pics. I may have a workaround solution for my issue with the way the WOT cutout works, I'll update on this later. For now, pics.
    Attached Images Attached Images
  10. #20
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    A couple more.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
