Page 9 of 46 FirstFirst ... 567891011121319 ... LastLast
Results 81 to 90 of 460
Thread: 87 "coug" resto winter project
  1. #81
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,417
    Feedback Score
    15 (100%)
    Default
    not too bad,, It appears worse than what it could be.
    so here are a few progress pics with fiberglass
    I had to peck the surfaces low to come back in with fiberglass and plan in some degree of a thin layer of bondo.
    the last picture is looking into the pointy out part that as a hole in it.
    Attached Images Attached Images
  2. #82
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,417
    Feedback Score
    15 (100%)
    Default
    here is some touch up I did with fiber to fill the passenger and driver drainage up near the back window
  3. #83
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,616
    Feedback Score
    17 (100%)
    Default
    Have fun. Body work is my least favorite thing to do. Next to suspension work.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  4. #84
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,417
    Feedback Score
    15 (100%)
    Default
    I don't mind it,,
    basically when I find an area of concern, blast off the rust then protect the metal, it makes me feel good knowing "I saved it" ~ for a little while more.
    Taking things in small manageable chunks helps a lot, that way you make progress on small pieces that add up.
  5. #85
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,417
    Feedback Score
    15 (100%)
    Default
    progress on the tail section
    first layer of bondo,, back with a second coat and should be good enough to blend with the rest of the car paint
  6. #86
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,417
    Feedback Score
    15 (100%)
    Default
    sub frames started
    47 3/4'' long per side
    steel is 1/8'' thick, sized 1'' x 2''
    passing through the front floor pan with 1/2'' carriage bolts w/ silicone on the inside and completely through the frame ,qty 2 connections up front per side
    passing through the rear sub frame with 1/2'' carriage bolts and through the over lapping sub frames to connectors on the rear, qty 3 in the rear per side
    this sub frame inserts into the front frame about 12'' or so and lays under the rear frame directly underneath the 2 conveniently provided 3'' spaced square holes I plan to use for the rear connection point,
    the angle of the bend is 175deg even
    this layout does not obstruct the Ebrake cable either.
    this will come together over the next week or so.
  7. #87
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,417
    Feedback Score
    15 (100%)
    Default
    oh yeah,, and the trunk is re-silicone treated to all disturbed areas.
    I need to use up a second tube on areas I think the factory neglected and improve the drain holes inside the trunk along the rear lower qtr panels.
  8. #88
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,431
    Feedback Score
    14 (100%)
    Default
    I'd weld those SFC's if I were you guys...if a welder was available.
    Think it was Jerry (daminc) that notched his floor pans, ran his through the cuts, welded it all up, and hid it with carpet afterward. Put a bend in the tube, it's going to weaken it, no?
    But then for just a street driven car, it's probably not that big of a deal, and removable if you ever want or need to.
    '84 Mustang, work in (sloooooooow) progress...
    '87 Stang notch
    1994 Ford F150 Flareside
    1997 Explorer V8 conversion (in progress)
    1998 Explorer 5.0
    and a couple of tractors. Ford, of course.
    FORD power, for life!
  9. #89
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,417
    Feedback Score
    15 (100%)
    Default
    thought up a different plan,, welding is going to happen, it will be easier to do it that way with this new plan
    the bend was required to dodge the floor pan,
    also the front frames are not the same distance apart as the rear frames.
    the front is wider apart than the rears, I would have assumed the opposite would be true but its not.
    the rear frames are about 1'' inboard more than its respective front frame.
    interesting the things you notice when you do other things that cause you to notice them.
  10. #90
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,417
    Feedback Score
    15 (100%)
    Default
    there will be a very very wide triangle steel plate on each side of the bent area to brace that bend
Posting Permissions
  • You may not post replies
  • You may not edit your posts
