Page 37 of 37 FirstFirst ... 273334353637
Results 361 to 365 of 365
Thread: 87 "coug" resto winter project
  1. #361
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,168
    Feedback Score
    15 (100%)
    Default
    got the motor trucking along, those home made permenant lift point brackets i made worked like a charm. they will stay with the engine.
    30$ a pair if interested.
    Attached Images Attached Images
  2. #362
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,168
    Feedback Score
    15 (100%)
    Default
    all bolted down, CW mounts worked perfectly.
    apparently the clearance for the TQ converter to the crank openning (where the converter nipples inside the crank) that tolerance is so perfect that the layer of paint i had put on was hosing me up and i had to pull it back out. I sanded the paint off and then added some anti-sieze.
    all dropped in now
  3. #363
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,168
    Feedback Score
    15 (100%)
  4. #364
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,168
    Feedback Score
    15 (100%)
    Default
    question...........
    my transmission double hump rear mount........
    can this thing be put on backwards?
    reason i ask is that the way it is now its choking off my rear transmission pan bolts badly.
    the two bolts from my trans rubber mount **ALL THE WAY TO THE REAR"" of my cross member slotted holes.
    DO i just pry bar the cross member towards the rear some?
    Ill get a pic if needed.
  5. #365
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,106
    Feedback Score
    2 (100%)
    Default
    It can go in backwards. I can't remember correct orientation, but the bigger hump goes passenger side I believe.
    Quote Originally Posted by jcassity
Posting Permissions
  • You may not post replies
  • You may not edit your posts
