Page 16 of 17 FirstFirst ... 6121314151617 LastLast
Results 151 to 160 of 161
Thread: My 85 TBird
  1. #151
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    463
    Feedback Score
    3 (100%)
    Default
    Covers are primed, light coat of 2330 plas-tick adhesion promoter and 3 coats of 33430 primer surfacer with 2350 flex additive. I will let them set a few weeks before block sanding and re-priming. Axalta products
  2. #152
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    157
    Feedback Score
    0
    Default
    Damn. Looks like i need to take a road trip up to Monona. You['re just over an hour north of me.
  3. #153
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    463
    Feedback Score
    3 (100%)
    Default
    bootleggers deluxe
    Well Iím guessing that puts you about 15 miles south of hwy 20. Come on up Iíll give you the short tour. Not that thereís a long tour.
  4. #154
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    157
    Feedback Score
    0
    Default
    I'm in Delhi. so like 3 miles south of highway 20. Maybe i'll boogie up some weekend, i'm typically working 6 days a week, so Sundays are fundays for me.
    You going down to Wild Wade's swap meet in Des Moines next Sunday??
  5. #155
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    463
    Feedback Score
    3 (100%)
    Default
    Most likely no, going to bid on an antique tractor down by Kansas City next Wednesday. If I end up with it will be on my way home with it on that day.
  6. #156
    Join Date
    Jan 2018
    Location
    Chesapeake VA
    Posts
    28
    Feedback Score
    0
    Default
    Cool, thanks, great stuff...I was gonna bite the bullet and grab a housing from one of the pre fab shops, like 300 to 400 bucks. Havent found anyone around here with the jig, but will keep looking. I will need to swap bearings ends from small to large and I know that usually costs me a couple hundred for narrow and bearing swap...so pre fab maybe just as economical.
  7. #157
    Join Date
    Nov 2005
    Location
    Louisville, KY
    Posts
    365
    Feedback Score
    3 (100%)
    Default
    Wow, very nice work on those. I need to pickup one of those older plastic welders. My Harbor Freight is not very good for this type of work. Do you have any tips for working with wavy covers? My 03 Marauder has the yellow urethane and the rear cover is wavy on the sides and the paint has spider web cracks. I tried to redo the front using some Metal Kote filler but now the paint is popping off the filler.
  8. #158
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    463
    Feedback Score
    3 (100%)
    Default
    Drewstang
    Heating them up and pushing out and in where needed is about the only way. I use a couple of body dollies and spoons to "work" the plastic around when its warm, then hold it there until it cools down. I wouldn't attempt to do this unless you plan on repainting the cover, more than likely to get things hot enough to move you are going to burn the paint. I rarely fix bumper covers here at the shop, it has to have just very minor damage or it gets replaced. More often than not you end up with more labor in fixing and prepping than the cost of a new one. Your Marauder rear cover is about $1350 though, so it may be worth putting some time into.
    By no means are my covers going to be what I would call straight, maybe it's possible to get them there, but to me would be an exercise in futility.
    This is the heat gun I use at the shop.
    http://www.autobodydepot.com/MRA-HG5...l#.WqST7bmWy5g
  9. #159
    Join Date
    Jan 2018
    Location
    Chesapeake VA
    Posts
    28
    Feedback Score
    0
    Default
    thanks on the plastic work, wondering about that myself. I used a good old Wagner heat gun to strip my Mustang...worked great...maybe not the best for a dedicated shop, but got the job done for a lot less...
  10. #160
    Join Date
    Nov 2005
    Location
    Louisville, KY
    Posts
    365
    Feedback Score
    3 (100%)
    Default
    Quote Originally Posted by bodyman View Post
    I appreciate the info, I hate asking about bodywork tips and tricks. I knew the rear covers were expensive, I just had to replace the front cover, header panel, grille, and impact absorber last year. I was an estimator for 3 years, and took a break but looks like I'm going back into the business as a shop manager.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
