Page 6 of 6 FirstFirst ... 23456
Results 51 to 59 of 59
Thread: The price of GAS!!!
  1. #51
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,211
    Feedback Score
    2 (100%)
    Default
    Quote Originally Posted by TOM Renzo View Post
    What I find funny, deisel is a byproduct of refining oil, as is natrual gas and propane. Much of it is vented to the atmosphere or burned as excess.
    NOT TRUE!!!!
    Natrual gas and propane are vented to the atmosphere as well as burned as waste fuel. Deisel isn't.
    Propane is almost always injected back into the ground through the recovery process. If there is too much propane still in the oil, it is further refined and burned off. Only about 12% of recovered propane makes it to consumers.
    Also my state regulates both propane and natrual gas to $1.75 and down to $1.35 when a gallon of gas goes over $4 a gallon.
    Quote Originally Posted by jcassity
  2. #52
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,211
    Feedback Score
    2 (100%)
    Default
    Tom, you may be right. Most of my research was done near 2005 as part of a science and biology class for my final project. A lot of my info is probably out of date. Propane and natrual gas used to be wasted a lot, and there were very few twin fuel vehicles.
  3. #53
    Join Date
    Oct 2004
    Location
    Middle Sackville, NS, CANADA
    Posts
    9,831
    Feedback Score
    6 (100%)
    Default
    I know they still burn it at the Dartmouth, NS refinery - you can see the flare stack for miles...
    1988 5.0 Thunderbird SOLD SEPT 11 2010: TC front clip/hood ♣ Body & paint completed Oct 2007 ♣ 3.55 TC rear end and front brakes ♣ TC interior ♣ CHE rear control arms (adjustable lowers) ♣ 2001 Bullitt springs ♣ Energy suspension poly busings ♣ Kenne Brown subframe connectors ♣ CWE engine mounts ♣ Thundercat sequential turn signals ♣ Explorer overhead console (temp/compass display) ♣ 2.25" off-road dual exhaust ♣ T-5 transmission swap completed Jan 2009 ♣
  4. #54
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,211
    Feedback Score
    2 (100%)
    Default
    They actually run those to burn off explosive fumes when the pressure is too high for the system to contain.
  5. #55
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,211
    Feedback Score
    2 (100%)
    Default
    We have about 5 refineries locally to refine gas through pipelines from wyoming. Two of them are visable frm the freeway and still burn just as thunderchicken said.
    This same plant also had an explosion that killed several people, wounded about a 100 workers, and blew out windows in residential homes several miles away. It passed an epa and osha saftey inspection about 3 weeks before the explosion, and it was even recommened they replace the parts that exploded. They decided it wasn't worth shutting down the plant due to cost of matinence, and loss of production.
    The local chevron refinery has had several pipeline bursts in the same sections over the past couple of years. Local athorities shut them down because it drains into a river where slc gets most of its fresh water. Chevron sucessfully lobbied to get the shut down lifted without any repairs, even after failing soil sample and with evidence of leaks, even before it was cleaned up from the last several spills.
    Regulations don't stop things from happening. Money does.
  6. #56
    Join Date
    Oct 2004
    Location
    Posts
    9,831
    Feedback Score
    6 (100%)
    Default
    I dunno if money stops things from happening, but a lack of it sure does
Posting Permissions
  • You may not post replies
  • You may not edit your posts
