Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Fire siren project, relay help needed.
  1. #11
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,634
    Feedback Score
    0
    Default
    Quote Originally Posted by Shadow View Post
    12v at both relays with a drop in amperage, compared to running a single relay, correct?
    Nope. Two relays in parallel will draw twice the amperage of one relay.
  2. #12
    Join Date
    Sep 2011
    Location
    south jersey, delaware soon!
    Posts
    2,260
    Feedback Score
    0
    Default
    really? interesting.. always thought it was an amperage drop because the single +12v supply can only feed so much
  3. #13
    Join Date
    Dec 2006
    Location
    Espanola NM
    Posts
    2,072
    Feedback Score
    2 (100%)
    Default
    There would be 2 12v sources. The first is a low amp switching signal from a toggle. The second would be a fused direct source from the battery using like 10ga wire. The Toggle source only activates the relay, it doesn't power whatever accessory. Then the 12v output (12v from bat) goes to said accessory. And of course there is the ground for the relay. If you picked up a 30amp 5 blade relay, then you would only need 1 as there are 2 12v output blades. Mount the relays some what close to where you have the sirens mounted. You won't but a little amperage drop/loss that way and almost a full 12 volts to the sirens.
    Wire size and length plays a big role in amperage loss
    86' T/C 2.3L
    86' T/C 4.6L DOHC
    04' Monte Carlo 3.4L
    16' Chebby Cruze 1.4L Turbo
  4. #14
    Join Date
    Feb 2009
    Location
    Belleview, FL
    Posts
    2,847
    Feedback Score
    8 (100%)
    Default
    Quote Originally Posted by 1BadBird View Post
    ^^^^^ this ^^^^^
    --Steve
    1988 Cougar V6
    2011 Mustang 3.7L
Posting Permissions
  • You may not post replies
  • You may not edit your posts
