Page 8 of 10 FirstFirst ... 45678910 LastLast
Results 71 to 80 of 91
Thread: Who has guns?
  1. #71
    Join Date
    Apr 2005
    Location
    Arkansas City, Kansas
    Posts
    5,978
    Feedback Score
    22 (100%)
    Default
    Guns? In this day and age... I don't believe in them!!!
    1988 Thunderbird Turbo Coupe
    1987 Thunderbird Turbo Coupe
    1983 Thunderbird Turbo Coupe
    1979 Mercury Cougar XR7 302HO
  2. #72
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,372
    Feedback Score
    14 (100%)
    Default
    Dude! We've sipped whiskey together. You ain't no snowflake, lol.
    '84 Mustang, work in (sloooooooow) progress...
    1994 Ford F150 Flareside
    1998 Explorer 5.0
    FORD power, for life!
  3. #73
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,760
    Feedback Score
    7 (100%)
    Default
    I took it as sarcasm.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  4. #74
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,372
    Feedback Score
    14 (100%)
    Default
    It was, I was kiddin' around with G, LOL.
    We've actually put lead downrange together. Don't think his wife liked my .30-06 with the handmade deer loads though. Then again, a rifle on the slimmer side sending 150gr .30 bullets out the barrel at 3,000fps isn't really mild to some. That said, a .300 WinMag is on the edge of "damn, this stings a bit". My 'ought six" is enough to kill whatever I need dead. Had it since 2012, always been a one shot kill affair, with regards to deer. Then again, my .303 British was, too.
    1998 Explorer 5.0
  5. #75
    Join Date
    Mar 2006
    Location
    Henderson, NV
    Posts
    117
    Feedback Score
    0
    Default
    Only have one- 9mm Springfield XD-M, 5 1/4in, a bunch of 19 shot mags loaded with Spear Gold Dot 124+P, Talon grips, IMI paddle holster
  6. #76
    Join Date
    Dec 2013
    Location
    Batavia, Ohio
    Posts
    38
    Feedback Score
    0
    Default
    I have .22 caliber Remington Nylon 66 I received on my 11th birthday, a Russian (not Chinese copy) SKS and a Marlin 30-30 lever action.
  7. #77
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,760
    Feedback Score
    7 (100%)
    Default
    Quote Originally Posted by tommym View Post
    I've spent a little time with a couple of XD's, and the grip safety is the most exquisitely uncomfortable thing I've ever had in my hand.
  8. #78
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,118
    Feedback Score
    15 (100%)
    Default
    just for the heck of it,, thought id throw this out there.
    Option A
    looking for 41 caliber rim fire ammo
    option B
    looking for someone to mod my gun to take an equal type center fire ammo
    process to option B...........
    drill center fire pin to allow a nail or smooth shank rod such as a drill bit to be the new firing pin.
    either sleeve the breach or rework the barrel to accept this new ammo or supply ammo that works which is knecked to match original design
    gun type is Waffenfabric M81
  9. #79
    Join Date
    Oct 2004
    Location
    Michigan
    Posts
    734
    Feedback Score
    0
    Default
    41 is an odd one, your most likely going to have to rebarrel it into something more common. Sorta neat it’s a needle fire though, that is some old technology. You’ll have to figure out what the bolt face will accept without heavily modifying it.
  10. #80
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,372
    Feedback Score
    14 (100%)
    Default
    I wouldn't bother modifying the .41, the thing is so old it's meant to be used with blackpowder, not the smokeless stuff modern guns and ammo use. For what it would cost a good 'smith to work it over, you could find good used Glock. Then again, if want to shoot it, be damned careful with loads, though I'd say you're going to a complete rechambering + different/new barrel.
    Nails don't make good firing pins...too soft.
    1998 Explorer 5.0
Posting Permissions
  • You may not post replies
  • You may not edit your posts
