Page 7 of 7 FirstFirst ... 34567
Results 61 to 70 of 70
Thread: 3g install **go directly to post 50 for drawing
  1. #61
    Join Date
    Dec 2007
    Location
    ONTARIO CANADA
    Posts
    490
    Feedback Score
    0
    Default
    ......another batch of info I find useful............and yes it's another long read! LOL
    http://sbftech.com/index.php/topic,2679.0.html
    84 COUGAR/88HO, 1.7RRs, performer RPM,700DP, equal length shorties, stainless EXH ,T-5,Hurst pro-billet, KC clutch, 8.8/ 4.10s, line-lok, bla ,bla, bla.
    Never shoot your mouth off, unless your brain is loaded! ....I may get older, but I'll never grow up!....If you're not laughing, you're not living!
  2. #62
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,418
    Feedback Score
    15 (100%)
    Default
    will update original with better looking drawing to include all the good feedback
  3. #63
    Join Date
    Aug 2012
    Location
    Pensacola, Florida
    Posts
    947
    Feedback Score
    8 (100%)
    Default
    ok question, I am gong to put a 3g in, but right now motor is out, but I have been doing the wiring getting things ready, I have the yellow wire that has the fuseable links tied into it, I have not uncovered loom to see the black and orange wire talked about in earlier post, do you have to undue those or will hit hurt just connect the yellow wire with ring terminal to the battery side of solenoid? I was little un clear on that part.
  4. #64
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,418
    Feedback Score
    15 (100%)
    Default
    the way you have that worded is confussing me.
    if you look at the drawings,, and if your able to save the drawing to a file.. then you can zoom in on the text... and read those embeded instructions..
    or press "shift" and then with your mouse wheel you "scroll" in or out.
    the drawings show you what you should have before and after,, i owe this thread a better drawing.
  5. #65
    Join Date
    Apr 2005
    Location
    Glendora, NJ
    Posts
    197
    Feedback Score
    0
    Default ford manual diagram
    I don't know if this will help. Along with the previous directions this should make the job easier. I just hope I don't burn my car down! I'll post the 2.3 diagram up too. Just gimme a minute.
    Attached Images Attached Images
    home ported E7's, HO intake, 93 Tbird cam, 65mm tb, Shorties, dynomax mufflers, TC 3.73 rear, Mach 1 springs, Bauman shiftkit, epoxy mod, SD, 3G alt, black magic fan
  6. #66
    Join Date
    Apr 2005
    Location
    Glendora, NJ
    Posts
    197
    Feedback Score
    0
    Default 2.3 wiring diagram
    Here's the charge/power distribution diagram for 2.3 turbos. The blurred text on the bottom left hand side is a ground to the engine G212.
  7. #67
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,418
    Feedback Score
    15 (100%)
    Default
    there are about 4 variations depending on year to the 2.3 on this wiring diagram,, perhaps only 3 but each one offers a different obsticle.. gotta be careful doing the 3G on the 2.3L.
  8. #68
    Join Date
    Apr 2005
    Location
    Glendora, NJ
    Posts
    197
    Feedback Score
    0
    Default
    The diagram came out of an 87 specific tbird/cougar service manual. I hope that will narrow it down a little.
  9. #69
    Join Date
    Aug 2012
    Location
    Pensacola, Florida
    Posts
    947
    Feedback Score
    8 (100%)
    Default
    i am using the brackets from a 92 mustang, what 3g alt will fit with that bracket set up?
  10. #70
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,418
    Feedback Score
    15 (100%)
    Default
    try not to post in this jerry, its a sticky for reference to the original topic.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
