Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: E-Brake cable questions *SOLVED* If you're swapping a TC rear in, READ THIS!
  1. #21
    Join Date
    Oct 2004
    Location
    Philadelphia
    Posts
    3,213
    Feedback Score
    8 (100%)
    Default
    I remember grabbing a spring with a hook from a car that keep the cable off the tire. I have to look for that I think I know where it is
  2. #22
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,079
    Feedback Score
    2 (100%)
    Default
    The '91'-92 parking cables are .75" longer, with a 3" longer sheath. My crude measurements shows the sheath length is as the ragged edge of working, however the extra total length should eliminate linkage modifications.
    Will the 3" extra inches of sheath restrict the cable from retracting properly at the caliper?
    Early Cable
    Late Cable
  3. #23
    Join Date
    Oct 2004
    Location
    Middle Sackville, NS, CANADA
    Posts
    9,830
    Feedback Score
    6 (100%)
    Default
    Nope. The sheath is longer, but when installed the distance between the sheath holder thingy on the caliper and the point where the end of the cable attaches on the lever will be the same. The sheath length will be taken up at the other (forward) end, which is likely why I didn't have to relocate the cable mounting lugs on my car and why the tire did not touch the cable. It might also be why I had to add some length...
    *Edit* I just noticed I had said '90 Mark VII cables in my earlier post. Must've been '91 cables, because they were the same as the "late" cable Jeremy shows
    1988 5.0 Thunderbird SOLD SEPT 11 2010: TC front clip/hood ♣ Body & paint completed Oct 2007 ♣ 3.55 TC rear end and front brakes ♣ TC interior ♣ CHE rear control arms (adjustable lowers) ♣ 2001 Bullitt springs ♣ Energy suspension poly busings ♣ Kenne Brown subframe connectors ♣ CWE engine mounts ♣ Thundercat sequential turn signals ♣ Explorer overhead console (temp/compass display) ♣ 2.25" off-road dual exhaust ♣ T-5 transmission swap completed Jan 2009 ♣
  4. #24
    Join Date
    Dec 2005
    Location
    Bethlehem,Pa.
    Posts
    4,049
    Feedback Score
    42 (100%)
    Default
    I used the 90 mark cable,but did make them work.I made new holders for the rear mount to change the angle.
    Old Grey Cat to this.88 Cat,5.0 HO, CW mounts,mass air,CI custom cam,afr165's,Tmoss worked cobra intake,BBK shorty's,off road h pipe, magnaflow ex. T-5,spec stage 2 clutch,8.8 373 TC trac loc,che ajustables with bullits on the rear.11" brakes up front. +
  5. #25
    Join Date
    Nov 2004
    Location
    So. NH
    Posts
    2,014
    Feedback Score
    1 (100%)
    Default
    I wonder what I did? I think I just rerouted the cable sheath, then I may have fed through a different cable - not sure - which I cut to length and terminated using cable stops to get the length correct. I may also have used a different sheath - man, I can't remember it's been so long.
  6. #26
    Join Date
    Jan 2006
    Location
    Vancouver, WA
    Posts
    941
    Feedback Score
    3 (100%)
    Default
    Just got my e-brakes installed after 6 months, for some reason I ordered the '90 cables, but I made them work. On the '00 Mustang rear axle/brakes I have, the tines on the caliper end don't go all the way through the bracket, but is so far holding nicely. I Did have to hog out the hole in the bracket about .025" .Ended up cutting the U-Bracket off(Early cable, pic above), and making new couplers out of 5/8" Pipe. Apparently I forgot that there is an adjuster to play with
    I also relocated the mounts for the chassis back about 4" to get the housing to curve correctly so as to clear the tire. Pics later!
  7. #27
    BogusSVO's Avatar
    BogusSVO is offline I'll have mine running one day.....
    Join Date
    Sep 2005
    Location
    Pensacola Fla
    Posts
    318
    Feedback Score
    0
    Default
    I guess I just took the easy way out.... I used the full set of cables from a 87/88 TC
    has 225k mile still with the factory head gasket
    84 Turbo ranger Daily driver ($800.00 Ebay deal)
  8. #28
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,431
    Feedback Score
    14 (100%)
    Default
    Nothing wrong with that, and I snagged the cables when I got my rear.
    But...ya can't get 'em new anymore...so when they seize up...
    '84 Mustang, work in (sloooooooow) progress...
    '87 Stang notch
    1994 Ford F150 Flareside
    1997 Explorer V8 conversion (in progress)
    1998 Explorer 5.0
    and a couple of tractors. Ford, of course.
    FORD power, for life!
  9. #29
    Join Date
    Oct 2004
    Location
    Philadelphia
    Posts
    3,213
    Feedback Score
    8 (100%)
    Default
    I looked for TC cables for several years in the yards and every single one I went to grab were either rusted or torched from some dingbat that cut the rear out of the car when it was in the JY
  10. #30
    Join Date
    Nov 2004
    Location
    Dover, PA
    Posts
    186
    Feedback Score
    0
    Default
    I just put these on our cougar. I want to say thanks for researching this. I used Brakeware #C10132 purchased from Autozone for a 91 Lincoln Mark 7. I did not have to do any cutting or spicing to anything. Cable adjustment nut is on by 1 nut width (no extra thread sticking out to loosen).
    Our web page
    02 Explorer XLT 4.0L
    04 F150 FX4 Supercrew 5.4L
    02 Saturn SL1 1.9L
    09 Vstar 950 Tourer
Posting Permissions
  • You may not post replies
  • You may not edit your posts
